ca problem
lifelicksballs
okay so i got my ca started finally but it idles really high like 1100 starts to really smoke alot and on one occasion i saw smoke come from the engine but couldnt relaly pinpoint from where...it coulda been a breeze that pushed the exhaust in there...and after a while it starts shaking alot and stalls
what could be wrong
oh and i dont have any intercooler piping connected or have an air filter but everything else is connected
ca18detdrift
Car: 89 240sx
wait if you dont have the intercooler piping connected, wouldnt your MAF be reading wrong?
rico05
Car: 1992 RMS13 w/ CA18DET
Color of smoke? Why whould you run the engine w/o most of it hooked up or installed?
sdtouge
Car: 1990 240sx coupe
the smoke is ok at first. my smoked like crazy, just keep an eye on it, weldeing hanks smoked alot too. its normal.
for the idle you can adjust the idle through the little screw on top of the intake mani sorta, its a 10mm, or your throttle body might be opend a little (if it is, when you rev it, itll take along time to come back to idle speed so youd know) then also the timming will affect the idle.
and yea, that is so janky to start it with out all that stuff hooked up man. seriorsuly lol. thats almost as bad as like, hmm my car isnt starting after the first swap, maybe if i drive it down this hill and jump start it that will help... lol cmon man. hook that stuff up beofre you start it again.
lifelicksballs
my bads, but it was just that i couldnt help it lol i just turned it on for only 30 seconds though i didnt think the filter or pipes would have made that much of a difference
240 Trainee
Ummmmm, the engine decides the AFR based on the MAF, if there is any extra air getting in the engine between the AFR and the engine itself, it will not run right, if at all. I would say missing pipes qualify as a place for extra un metered air
