Ca Pistons
tx_widebody
Car: nissan 240
I need stock pistons can someone help please!
boost_boy
tx_widebody wrote:I need stock pistons can someone help please!
How many you need? Got good condition ones with good rods as well. Check your mail..........
Dee
tx_widebody
Car: nissan 240
YESSSS i only need one how much do u think it is worth to u.
biosehnsucht
offtopic but hey, another local! (In texas anything less than 2 hours away is local, IMHO lol)
there's not many of us in the area but we do exist. I've got my AIM handle listed in my profile, feel free to ask questions and I'll do what I can (this goes for anyone, but esp. for the locals - as if worse comes to worst I might be able to actually GO and help), and if I don't respond don't despair, give me an email to contact you at if you go offline in that case cause I often am 'online' when asleep or otherwise not available but I'll never intentionally ignore anyone.
boost_boy
tx_widebody wrote:YESSSS i only need one how much do u think it is worth to u.
One piston= $24.00 shipped.
Dee
tx_widebody
Car: nissan 240
Is that for the piston top only?
boost_boy
tx_widebody wrote:Is that for the piston top only?
If you're referring to the piston itself, then the answer is "Yes".
Dee
tx_widebody
Car: nissan 240
OK how do we get this done
tx_widebody
Car: nissan 240
Is it easy to get the top of or do i have to take it to a machine shop
boost_boy
tx_widebody wrote:OK how do we get this done
Check your mail as I've sent you an email last night (hopefully you didn't delete it).
Dee
boost_boy
tx_widebody wrote:Is it easy to get the top of or do i have to take it to a machine shop
You'll have to remove the head and the oil pan. The best thing to do is remove the oil pan. How did you mess up a piston? Did you run high boost for too long of a time? Or did you just overboost it? Be wary of this as you can mess up more than one piston by cracking the ringland and it going unnoticed. I would pull all the pistons first because I'm sure you may very well have more than one that's screwed. And if you have only one messed-up, then consider yourself lucky. I once popped all 4 at the same time.
Dee
tx_widebody
Car: nissan 240
Well actually i bought the motor comletly apart, and when i was looking everything over i saw a peice that was broken write above the second ring, but only on 1 piston. Oh and i sent u an email.
tx_widebody
Car: nissan 240
So how do we get this transaction going
boost_boy
tx_widebody wrote:So how do we get this transaction going
You got mail.
Dee
tx_widebody
Car: nissan 240
Now u got mail
boost_boy
tx_widebody wrote:Now u got mail
Now you got mail !
Dee
tx_widebody
Car: nissan 240
It say that i have no new msg
boost_boy
tx_widebody wrote:It say that i have no new msg
I've forwarded my previous message. Try again.......
Dee
tx_widebody
Car: nissan 240
U wouldnt happen to have a set of main & rod bearings would u
CA19DET
have the block checked by a machine shop as if you broke a piston ringland, you probably messed up the block (or whoever did teh damage)
tx_widebody
Car: nissan 240
Yea i am
boost_boy
tx_widebody wrote:U wouldnt happen to have a set of main & rod bearings would u
I do, but they are .50 oversized. If your crank needs to be cut, then you may have some use for them.
Dee
tx_widebody
Car: nissan 240
naw i think my crank is good, so r we gonna do the piston and the ring set, if so could you explain it to me please.
boost_boy
tx_widebody wrote:naw i think my crank is good, so r we gonna do the piston and the ring set, if so could you explain it to me please.
You got new mail!
Dee
tx_widebody
Car: nissan 240
UV got mail
boost_boy
tx_widebody wrote:UV got mail
Your turn to go check your mail.
Dee
tx_widebody
Car: nissan 240
ur it
boost_boy
tx_widebody wrote:ur it
You've been zapped!
Dee
tx_widebody
Car: nissan 240
Which way do u think i should have done it
tx_widebody
Car: nissan 240
MAIL CALL
