CA Boosting
Kouks
Car: 1996 Nissan 240sx S14 Sr20det
As read in the FAQ, 12 lbs on stock system, Is 14-15lbs just too much, Im running a SR t25. IF i have an AFC(the original one) and get DSM injectors can I run 1 bar safely. Just trying to get a feel of what to expect from the ca. this is going to be my daily driver.
float_6969
The injectors aren't the limiting factor as much as the stock sidemount. You either need to get a good sidemount (ARC) or get a FMIC.
Loofee95SE
Car: u gota sister??
I was running 15 psi on Fmic, Sr T25 (.80 a/r) 3" dp, cat, and exhaust, walbro 255, and old style AFC, with no problems. but I think i was maxing out my maf,. C
sideways danny
Car: s13, CA18DET
I ran 14psi on a s14 t28 with the standard WMIC, standard AFM an ECU chip and a filter and exhaust for 18 months with no problems
Kouks
I would be running a FMIC set up, but on stock internals with 85 ticks. I got a HKS headgasket and Intake Cam I believe.
