CA a/c problem
Ghost_silvia
Car: 1991 nissan silvia s13
I was trying to bolt up my CA a/c with my 91 240sx stock lines and it has a gap where it attatches to the compressor do I need sohc lines?
NeedCAforS13
Car: CA swapped S13 coupe
what?
you either need sohc lines and compressor and CA18DET pulley, or custom lines and CA18DET compressor... your twin cam lines won't work with anything.
Sean
c-rad
Car: 1991 Nissan 240SX w/CA18DET
NeedCAforS13 wrote:what?
Sean
Well, if you have the fittings for the CA compressor, then you can just braze those fittings to the DOHC lines...
NeedCAforS13
brazing = custom
thats what I did chris... worked really well. you can also tig weld them if you know someone who can weld aluminum.
Sean
kim
Car: 90 240sx, 97 M3
So you can use the AC compressor from a Sohc Ka? I need A/C bad please give more info. I tried searching with "CA18DET A/C" but it comes up with other stuff.
Thanks,kim
float_6969
I've got everything you would need to have working A/C on your car. I've got both lines, a SOHC compressor and a CA compressor. You can either swap the pullys, or I can have it done for you so that all you'd have to do it bolt it all up. That way it would be plug-n-play. No welding/brazing.
I don't know what it would be worth, so somebody make me an offer. I keep forgetting it's in the garage...
biosehnsucht
has anyone yet actually proved they are swappable?
also, the FSM shows two different CA compressors, once that looks nearly identical to the sohc KA one (and thus might be swappable) and the other that isn't (and possible not swappable); unfortunately I've two of the latter type (one of which is seized, the other is usable, probably)
float_6969
my SOHC and CA compressor look identical except for the pully and the connections.
biosehnsucht
bastich :P
I should be able to use one of my compressors, but I want to see how far off they're positioned.. perhaps its feasible to grind down one side of the AC bracket and make a small spacer / user washers to fill the gap on the other side to move it back/forward (forget which way its off)
kim
Hey Float, What do you want for the compress or with the pulley on it, I already have the sohc lines.
float_6969
Email me HERE with an offer.
