bypassing the need for an aftermarket deck to install subs/amp???
All things Altima Coupe.
Desire1314
Car: Altima Coupe 3.5SE 6MT
i was wondering if anyone was able to do this. im planning on getting a set of 2 10' alpine type E's (since 12's would be too big and the type R's is more than enough). BUT, i wanna keep our factory deck, because im pretty sure if i get an aftermarket one, the controls on my steering wheel will be useless.
any help or suggestions?
Infantry1327
Car: 08' Nissan Altima Coupe SE
I still have my stock nav unit with my 2 10" alpine type X. I just spliced them into the 6x9 speaker wires. But you will get much better sound quality out of a after market deck and hooking them up via RCA. I plan on eventually getting a new deck but money is tight.
AppleBonker
Check the FAQ. You can still use your steering wheel controls with and aftermarket deck!
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Desire, I run the Bose HU with a two Infinity Kappa 10.1 subs. Not sure if I did a write up on it but you can find the thread here
saywat
im not a fan of audio converters
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
depending on what your budget is, you can also install a top of the line digital sound processor like an audison bit one unit... and in addition to making your factory system(with Bose amp) sound better, you can also use the RCA outputs to send a cleaner, more powerful signal to your amplifier powering your woofers...
