yardidigital wrote:I just had 2 alpine mrp-450 amps installed with 2 alpine 12 type-R's. When the radio is off or turned down low the subs buzz. I called the stereo shop later after I picked the car up and they said that it is normal with the bose system. They said that the bose microphone creates that noise to cancel out road noise or cabin noise. I have had pretty nice stereo systems my whole life and have never come across this issue and it not be a ground loop problem or signal wire issue. Any thoughts or help would be great or even something to suggest to the shop so they can fix it. Thanks in advance. Hi there ,its a simple fix for your problem just locate the rear mic on headliner pull and clip wire problem solved. have a nice day
