Buying my first TT Z need some advice/tips!
skypad
Car: 91' Twin Turbo 300zx 5spd
93' N/a 300zx 5spd
93' 240sx 5spd
Hey yall, so I'm looking to buy this 91' TT with 42K on it. Original owner, has always ran off stock boost 9-10 PSI. I own a 93' NA atm, and perform my own routine maintenance. I was looking to get some advice for when I go to look at the car and test drive. What are some things I should keep in mind to know if it's a good find or not? He does have maintenance records ect. ect... If I do decide to go with it I need some advice on how to properly maintain a TT z, what oil to use ect. Thanks for any tips or advice in advanced!
BusyBadger
Car: '92 Nissan 240SX
'05 Nissan 350Z
'13 Nissan Juke
I'll just move this out of Z33/34 Tech and over to Z32 Tech where I'm guessing you intended to post it.
Zwicked
Car: 1990 300 ZX tt, 1990 240SX
I would say you can count on doing the major T-belt service as soon as you get it unless he has records of getting it done. It's not over mileage but it is way past age due date.
Sounds like you may have found a keeper with such low mileage, congrat's!
Here is a good little writeup for people considering a purchase
http://www.twinturbo.net/ttnet....html
skypad
93' N/a 300zx 5spd
93' 240sx 5spd
Thanks BusyBadger for moving the post, it was late when I made the topic last night lol...
Also thanks Zwicked I'll keep that in mind, as well as use the link you provided to refer to. The belt change is usually apart of the 60K maintenance if I'm not mistaken? As you mentioned, it would be better to get it done ASAP anyway... Thanks again!
car nut
Car: GT500.
Yes, it is. I'd definitely do a compression test. Make sure the car pulls and the turbos feel like they're fulling spooling. Watch for smoking. Sniff the exhaust to check for coolant or oil. And check for rust. Sounds like it might be a keeper with that mileage...
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Also, as I'm sure you're aware, listen for lifter ticks both while cold and warm. A lot of problems can be "hidden" when test driving a car by letting it warm up before you get there, so make sure he leaves it cool.
skypad wrote:Hey yall
From Jersey? Where are you really from?
skypad
93' N/a 300zx 5spd
93' 240sx 5spd
Thanks yall, I'll keep everything in mind when going to look at the ride.... What about getting the trans flushed it is a 5spd. I heard if it hasn't been done to the ride in the past than I shouldn't bother don't know how true that is or not. Also I was looking around for a 60K maintenance package, can someone provide a link for a well priced package? Should I just take it to a nissan dealer and tell them I want the "60K package" done, or should I get everything first and just let them do the labor. I myself don't have the proper tools to do any timing work ect.. What all should be included in the 60K maintenance?
Modified by skypad at 5:50 PM 1/19/2010
car nut
Car: GT500.
Lol, don't ever take your car to a dealer to have them "do what needs to be done". Dealers should be called stealers, cause that's what they try to do.
http://www.courtesyparts.com/b..._7695&
skypad
93' N/a 300zx 5spd
93' 240sx 5spd
car nut wrote:Lol, don't ever take your car to a dealer to have them "do what needs to be done". Dealers should be called stealers, cause that's what they try to do.
Yeah this is true and the sad part is a close member of the family used to work for a nissan dealer in maintenance up until about a year ago.... So my problem is, I'm not sure where to take it to have the work done, and without a lift it would be nearly impossible to do all of the 60K maintenance.... I live in NJ in Burl. County, if anyone knows of a good shop to take a Z to that would be great. So, should I go with this entire package, or stick with just the timing?
car nut
Car: GT500.
You can pretty much never overdo maintenance.
skypad
93' N/a 300zx 5spd
93' 240sx 5spd
Yeah, I've decided to go with the entire package, now just need to find a good shop in jersey :/
JDMZ32
Car: 1991 Nissan 300ZX NA slicktop 5spd red
Joisy. Hope you're not a Yankees fan. Good luck finding a good shop.
skypad
93' N/a 300zx 5spd
93' 240sx 5spd
JDMZ32 wrote:Joisy. Hope you're not a Yankees fan. Good luck finding a good shop.
Hehe, thanks and I actually am still contemplating if I should do it myself or not. After reading up on the guide for the 60K package on TT.net, it seems I can manage doing so myself. I'd just need to go out and get the proper tools. The only problem I see running into would be removal of the intake and exhaust cams to replace the seals.... seems difficult. Other than that the rest seems fairly simple with the proper tools, and time.
