Busted clutch whats the problem?
Nicksemianiw
Car: JDM 89 Silvia K's
1989 Nissan Silvia.
So all of the sudden when I went into my car yesterday my clutch dident want to work, the clutch feels mushy and I can't put the car in gear. The pedal also doesent come back up all the way. I only get like 1-2 inches of clutch feel at the bottom near the floor. Is it the Clutch slave cylender? if so where can I get one that will work?
ilovecoupes
try bleeding the hydraulic system.
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
with the age of our cars... just replace the slave and master for the clutch... your going to need to eventually and its under 100 to replace both plus about 40 minutes of work. one of those is most likely your problem, i had that issue driving around one night, had to revv high and jam it in 2nd to get moving lol
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Probably just the slave cylinder. My clutch seems to eat them once a year or so. Luckily, just go to Auto Zone and ask for one for any year s13 240sx. They are $11.
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
simplest answer... is the resovoir full?
dot3 brake fluid my friend.
Nicksemianiw
The resovoir is full.....hmmm
r34 gtr
Get under there on the passenger side behind the front wheel and see how your slave cylinder looks. The rubber clutch hose going to it will often blister up really bad so you can't actually put any fluid pressure to the cylinder, if that makes sense.
