amc49 »
https://forums.nicoclub.com/amc49-u275146.html
Tue Dec 11, 2018 3:57 pm
So, you don't think a pulley checked 'a few months ago' can be bad now? Bad thinking there bucko. And if the belt was one made to cover more than one length (typical 1/4" at a time) by being in between sizes then a few months ago could have a semi-loose fit OEM belt now slipping. I don't know if Nissan uses range indicators on their tensioner assemblies but if they do that might show you. The tensioner needs to be running close to the center of its range, or toward the tight side, toward the loose side they can slip. Even more if the belt has worn in to vary length down it to then make the tensioner arm action erratic. A belt can be loose with no noise at all. Pulleys sometimes make none either. You spin everything not just idler, the power steering and water pump even though usually not that and a/c for sure, alt and tensioner roller and the arm swing. Swing the tensioner arm through its' working arc and check for any sticking which will let the belt slip for a second to skid it and the smell.
The battery cable might be part of it, but the smell should be over by it, but smells being what they are are commonly misleading as to source. The cable gets hotter the more resistance it gets. Hot enough it melts the plastic insulation and you smell that.
