'02-'06 had a recall, Altimas and SE-Rs, to reprogram the ECU upon other crankcase measurements.NSR_s30 wrote:Altimas with the 2.5 have had the same problem too of eating oil only between certain years though. Take it to the dealership and get it sorted out.
If you have the recall open on your vehicle, a dealer CANNOT turn down working on it because of modifications...as long as your basic engine is there, they have to perform it. So, I agree with the above statement.nametakennow wrote:It shouldn't, but if they jerk you around you may have to go to a different dealer for simplicity's sake. By jerk you around, I mean they may try to claim that it isn't a recall issue and it's your fault.
yes, if you read your owners manual and warranty info....any of the above could be reason enough for them to turn you down. though they can't deny the fact that they recalled just about all the QR25's. DOH! To ensure you don't get d!ck around I would put it back to stock or as much as possible. Though if you do have nismo performance parts, it might not be as big a deal. just my $.02.1toomanyspecv wrote:Will tha fact that i have aftermarket parts (CAI, catbak exhaust, headers, throttle body spacer) affect nissans compliance 2 tha recall?
listen to nametakenow and nissantech, they are right about them being obligated to fix the problem if it is a recall, mods or not. you might want to read the Magnuson-Moss Warranty Act to give you more of an edge when dealing with the dealership, or just check out the thread below. good luck.1toomanyspecv wrote:Will tha fact that i have aftermarket parts (CAI, catbak exhaust, headers, throttle body spacer) affect nissans compliance 2 tha recall?
