Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri Jan 09, 2004 3:33 am
Anytime you use NON oem quality bulbs anywhere in the system you risk burned sockets, burned wires, burned relays, failed sensing modules.
Buying bulbs at autoparts stores is a kind of slow suicide, many dealers may cut corners and not use the oem Toshiba quality bulbs.
You never know what the bulb start [inrush] current is, nor the operating current unless you measure the amperes.
As the voltage goes up, the current goes up [alternator troubles].
Atmosperic pollution lets oxides form on the contacts which can cause corrosion and overheating arcing.
Examine all external [higher wattage 1156,1157, etc] bulbs at least once per year to catch problems.
#1156 : 12.8 volts, 2.1 amperes, 26.9 watts
#1157 High Element 12.8 2.10 26.8w 32 402lum 1200 Low Element 14.0 0.59 8.3w 3 38lum 5000
Each rear 90-93 Q light assembly can consume 98 watts when the headlights and brake lights are on..........thats more than a headlight 55/65 watts..........the 94 use only 2 instead of 3 rear bulbs= 62 watts.
