DaveEEE »
https://forums.nicoclub.com/daveeee-u406.html
Tue Oct 07, 2003 11:09 am
After getting the head resurfaced and installing the cometic headgasket this weekend on my built KA, we cannot get it to run. At first, it wouldnt catch at all when cranking. Took distributor back out, was off a tooth, fired right up the next time. However, will idle at only about 300-400 for a few seconds and then die. I seem to have no throttle response so I cannot rev it and keep it alive. It just floods out the motor with fuel and soaks the spark plugs from trying to crank.
We checked the MAF, TPS, etc. All seem to have continuity. While checking the timing while starting, we cannot see the marks. Why is this? We set it to TDC, timing light flashes but does not show the marks. All harnesses seem to be connected, and it sounds fine while pressure testing, it doesnt seem as though there are any vaccum leaks. Once it does start however for the brief period, I didnt notice the boost gauge go into vaccum at all.
ECU doesnt throw any codes either. Our thought was it was something simple, such as a loose harness, bad sensor, or vaccum leak. But I feel as though we've ruled all those out. So, time to look back at the timing? What would the affect be if the bottom timing chain slipped off a tooth while we were supporting the upper chain changing the headgasket? Would it start at all like it does? I sure hope we dont have to take that bottom cover off.... Any thoughts? Its been 3 days and we cannot make any damn progress.
-Dave
