Well I know i've posted it before but I'm entirely too lazy to try to find it again so here you go:
Block:Ross Racing 8.5:1 pistonsPauter Machine rodsbored and honed .020 overhot tanked and cleaned upblock decked .004ish (needed a fresh surface there)cleaned again and re-assembled to OEM specs with all new bolts and gaskets.
Cylinder head:cleaned uphand port and polished slightly on the exhaust side by me, we'll see how that one works out...new timing chain kit
Performance parts:T3/T04E turbo 50 trim compressor, .63 a/r turbine stage 3 wheel (whatever the heck stage 3 is it's pretty standard)Import-Autoperformance.com exhaust manifold with deltagateEbay Intercooler with I think 21x8x3 core.
Fuel:JWT ecu72# hr. injectors (the "75#" delphi injectors from http://www.racetronix.com)JGY Customs fuel rail with aeromotive FPRWalbro 255lph HP fuel pump
That's all the stuff that I've bought paid for and have in my hands...I'm still working out the IC piping and cant decide between a pre-made drop in set or putting together my own. The exhaust will probably be a full 3 inch turbo back with two dynomax straight through mufflers. If I've forgotten anything or you have any questions let me know
It should all go together and get running over Christmas with luck.
As for making 350hp, it's been done with 15psi, you have to remember that 10hp per psi is a very general rule and sometimes it works out...sometimes it doesnt. I know someone who has hit 22psi on a stock block...but only once and only because he could afford a blown engine, there are people daily driving 15psi on stock blocks though
