Sorry, as mentioned the 2+2 is only longer and mostly the wheelbase, not wider anywhere...same platform just stretched a tad longer.Veganpotter wrote: ↑Fri Apr 06, 2018 9:47 amAwesome, thanks for doing that!!! I know the 2+2 is a bit wider. Hopefully a bit of that is in the engine bay too. There's a good chance I'm going to have to modify the panels if that's not the case. Hopefully there's clearance with the actual struts.
Not sure which part of history you're referring to but in my fairly extensive experience with EJ205s 207s 255s and 257s head gaskets have never been a failure point, now ringlands, that's another story.evildky wrote: ↑Wed Apr 11, 2018 9:03 amThought he wanted eco friendly 400 hp?
Obviously 400 hp can be had with forced induction but something like the SR would fit better and do the same job without the subaru head gasket issues. I'm told the newer subaru engines use timing chains. Historically you did your timing belt and head gaskets at the same time on subie's.
Just saw this. The narrow portion is the forward portion of the frame rails of the unibody. It's a continuation of the structural portion where the jack points are.Veganpotter wrote: ↑Sun Apr 08, 2018 5:05 pmI just took a quick peak at the narrow portion. I'm hoping that's just an enclosed area for wiring or something. It seems like its fairly thin metal and I'm hoping its not structural...
Ha, if it is, I'm going to need to get a different drivetrain than what's on its way![]()
Evildky, the SR is easy but its a pain in the a** to even pass emissions AT ALL. I want my car to meet emissions standards of a new car. I'd love a Toyota engine too but they aren't spitting out modern RWD drivetrains outside of their guzzling trucks and I can't afford an engine out of a new Lexus SC. Emissions for me also mean gas production emissions in addition my car's exhaust. I know people getting close to 40mpg on the highway in their 100% stock BRZs and we have high speed limits in Utah. 70 and even 80 on some places.evildky wrote: ↑Tue Apr 10, 2018 8:50 amSo you're putting a BRZ drivetrain into a Z32? I'm sorry, I'm into weird stuff but this one makes no sense. 200 hp motor from a 2600 lb car into a 3200 lb car that came with 222 hp....???
I've driven the toyobaru's and they are great little cars, fantastic chassis, great use of space, light weight, I just don't trust that subaru engine. If they came with a toyota engine I'd have one.
