Define "brackets", do you mean the part that actually bolts to the knuckle? If so, you need the COMPLETE caliper from the Brembo set, the Brembo caliper bracket is larger than the standard brakes.nismo2K2 wrote:so then i wouldn't need the brackets off a spec v that came with the brembo package? right?
+1TKOcrewSR wrote:the brembo caliper are a non floating design which means that the caliper bolts right to the knuckle, which means in mot cases there is no other brackets in this case im not to positive with the spec-v but i'm almost positive the caliper bolts right up with no plroblem all you should need then is brake lines and rotors off a spec v so it should bolt right up
