Breathing prob?
skdline63
hey guys, since rebuilding my ca18 its been breathing quite a lot and leaving a bit of water in my catch can. im still running it in, just wondering why would it be doing that? before i rebuilt the motor it hardly breathed at all. thanks
themadscientist
I have this mental image of an engine panting like a dog. Water in the catch tank? That is weird. Are you sure it didn't get there before you put the motor back in? I can't see how water would get in the catch tank.
Nunook
do you mean the overflow bottle connected to the radiator?
cause u def shouldn't be getting water in ur oil catch can.
skdline63
nar breather bottle connected to motor, not radiator. jst a bit of oily water in the bottom of it?
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
Sounds like you got a leak. maybe the HG didnt seal properly?
HighwayStar22
Car: 2002 RSX Type-S, 1991 240 Hatch
Tell it to stop smoking and exercise more.
Haha. Sorry I couldn't help myself. Check around the number 1 cylinder and the water to see if you've got some particulate in there. I'm with gabby, the hg may not have seated properly.
skdline63
the lil bit of oily water in the catch can has only really started since it has devoloped a lil miss on idle and the ecu is throwing the number 13 code which is coolant sensor? any help would b awsome cheers guys.
skdline63
