Brakes Update.
rectangle_nyc
Car: 1994 Nissan 300zx Twin Turbo
Hey Experts.
I am looking to upgrade my brakes on a 1994 300zx TT. I need new rotors, pads and lines.
I was looking at StopTech Slotted Sport Brake Kit - 977.42005 but i don't have a definitive answer if they will fit a TT. No one seems to know.
Looking to spend around $500 not willing to change calipers since they are in good shape. The rotors i was thinking to get slotted only, not drilled. It is a daily driver not a race car.
Any suggestion are appreciated.
Thanks.
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Check here:
I would recommend 300 degree BMC brace and fresh fluid in addition to your list.
http://specialtyz.com/shop/default/300zx/braking.html
rectangle_nyc
Thanks. I got couple of cans of Motul fluid. Will get the brace. Is it a PITA to install? Do you know if stoptech 977.42005 will fit a tt with stock rims?
itsa300zx
2011 Nissan Rogue S
2008 Highlander SR5
Easy to install BMC brace, just the bolts holding the fuel filter, it should come with two longer bolts.
If they are OEM size, yes will fit s:)
rectangle_nyc
Thanks. Appreciate it.
