240man91 »
https://forums.nicoclub.com/240man91-u169644.html
Sun Mar 20, 2011 1:13 am
i have never really looked at mine, but on most cars it can come undone where the cable from the ebrake hooks up the cable that runs the back breaks. just look under the car in the middle an u should be able to see it, its right abovr the drive shaft an make sure the cable did not come unhooked from the wheel. an if it worked be for then it came unhooked some where, when u push the back breaks u do have break on that side right? an there is an adjust ment but is on the cable that comes off the ebrake. an there is one at the handle of the ebreak. but if one grabs the other should.
