BusyBadger »
https://forums.nicoclub.com/busybadger-u28281.html
Wed Oct 15, 2008 6:46 pm
You're might be the first person I've known to say that the Hawk HPS pad (for the Z33) is amazing. Most times I read or hear about how anemic their performance is. They do seem to have a pretty low dust level and seem relatively cheap though. I run HPS pads on my S13 and I think they are an amazing upgrade over stock, but then I use SPL steel brake lines, powerslot rotors and Dot 4 fluid too, so I'm sure its not the pad alone.
27K sounds like a decent lifespan for pads - it is just pads isn't it? Just as in tires, there are some compromises to be had in terms of performance vs lifespan when it comes to pads. All other things being equal, I wouldn't expect the same performance from Hawk HPS pads as I would from a set of Ferodo 2500's, but I would certainly expect a longer pad life.
Brembos on your 350 or no?
