Brakes = RPM drop?
S13s Lost Illusion
Car: Drifting, Girls, Pool
I'm getting this problem in my car where, when I press my brakes it drops my RPMs instead of raising it at idle, ie. 700 RPM to 550-600 RPM.
I don't understand what's going on. I don't know much about the theory behind the mechanics of the cars, so I can't really troubleshoot myself.
Can someone tell what the problem is?:confused:
Silvia007
Car: 93 Nissan 240SX SE Fastback
Does the RPM drop when you press the brake at stand still? Or does it only do it when you are moving? It could be a power problem... I notice that when I play loud music and I'm at idle, everytime the sub produces really low frequencies my rpm would drop to about 500 also... this is because I don't have a capacitor... oh well... you could try new battery/alternator. My theory behind this is when you step on the brakes the lights come on which chews up power quicker from a sour battery.
Exar-Kun
Car: 2005 350Z
is it going back up right afterwards, or stayling low? mine goes low for a second then pops back up to normal..-chet
MadSideways
Car: Cars, women, drifting...the usual...heh
It sounds like a vaccum leak....check your hoses for cracks or loose clamps...particularly the brake booster hoses...
GodDrivesA240sx
Car: 1995 Nissan 240SX
MadSideways wrote:It sounds like a vaccum leak....check your hoses for cracks or loose clamps...particularly the brake booster hoses...
:yesnod :yesnod
91nis240
nah its normal, 240's have all kinds of little rpm fluctutions when idling, my rpm's drop when i press the break and even when i open my door lol crazy.
S13s Lost Illusion
91nis240 wrote:nah its normal, 240's have all kinds of little rpm fluctutions when idling, my rpm's drop when i press the break and even when i open my door lol crazy.
LOL
thanks for the Info, makes me feel much more relaxed.And I'll check my lines for vacuum leaks also.
4cefed
Car: 92 240SX Coupe
03 SRT-4
Various Dodge POSs
I use ether to check for vacuum leaks. I haven't even set anything on fire!
