brake noises
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
holdgee
Hi all
Just had my disk brakes change within 3-4 weeks ago and now I am getting a screaming noise when i gently apply them? This should not be the case I pressume. I know it normally takes a while for bending of the new brakes but should i be getting these noises when i gently apply them?
what should I do ? and is there any thing i can do myself to rectify the problem ?
thanks
BlueMango
Car: 2008 Nissan Versa S Hatchback
Google brake bedding procedure. It will tell you how to get them broken in properly. Also you can try adding anti-squeal grease paks.
Sometimes it's just a dust issue. Do you drive down lots of dirt roads or through lots of construction?
holdgee
I am normally up and down alot of hills not that dusty a road but since iam relatively close to the sea i believe that may also have something to do with it
kcourtad
Car: 2007 Nissan Versa SL Sedan
dude mine scream going down hills so i went and picked some up... and they were fine... so i just took them off and cleaned them out and they dont scream anymore
Return to “Versa Technical Discussions”
