?Brake noise? 1993 PU XE 4x4 150k miles
seansays
Car: 1993 XE Pickup extended cab 4X4 manual
once the vehicle has driven about 10 miles/when slowing down <30mph a squeal like noise is heard regardless of throttle activity, clutch activity. sound is intermittent post application of brakes/ does not occur when rolling backwards only when moving forward in neutral or in gear regardless of steering wheel direction/ brake hoses are new/fluid is clean/ braking is great/rotors and pad ok/just replaced front left brake caliper and pins as it had been sticking
Please suggest what I should do next. Replace pads to insure they are OEM? Wheel bearing seem ok but?? repack inner and outer front bearings??
thanks- s
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Take off the wheels, spin rotors by hand perhaps.
seansays
i.e. to see if the rotor is sticking? well, I replaced the sticking rotor yet the sound continues....so I guess you are suggesting I try this again...hopefully I can get it to make the sound and then put it up on the rack to check as per your suggestion....do I got this right?
Thanks for the reply S
WWJD
Cheap pads will cause this, cracked pads will cause this as well. I would say get new pads and put High temp. greas on anythig that will touch metal Except on the pads surface.
your shoes will cause this as well if they are cracked, along with you drum springs. the spring do 2 things in the rear keeps tention on the shoes so they stay in place and dampen vibration. Also if there is no greas on the backing plate where the shoes rest, that could cause it as well
