Brake Light Problem
SSJ4Gogetta2000
I recently got my 240SX, a 1992 Coupe, and the only thing really wrong with it is that the Brake lights do not turn off by themselves.
If I park the car and turn the car off, the brake lights still stay on. Someone told me to checked the fuses and the brake fluid level. I did and there are no problems there.
The only way I can turn them off, so I do not drain the battery, is to disconnect the connector to the sensor by the brake pedal. I therefore think that it has something to do with that sensor, but I do not know what to do from there.
:confused: :mad: :confused:
Any help would be greatly appreciated. Thanks in advance.
P.S. I am talking about the brake(stop) lights on the rear off the car that brighten when you push the brake pedal down.
erich
It's probably just a bas brake light switch. Remove the switch and check it with an ohmmeter or continuity checker.
erich
Cosmic_Ray
Car: Motorcycles
Better yet leave it mounted, just disconnect the wires and continuity the terminals. They should be open circuit until the pedal is pushed.
CR
