You shouldn't have to open the bleeder valves. Did you open them to put the pads on the caliper? Next time, use a big set of channel locks if you can't find a brake pad depressor. It sounds like you got air in your system from leaving them open while putting the new pads on. Don't worry, you aren't the first to ever do that.kruuth wrote:Yep, they're tight. I know I lost some fluid when I changed the pads though.
How do I change pads without opening the bleeder valves?
You remove the master cylinder cap to allow room for over flow then use channel locks or some other sutibale tool (screw clamp) to compress the piston, it dosen't require much pressure. It helps to have someone watch the master cylinder while you do this to make sure it dosen't overflow, and if it gets close use a suction pump to remover excess fluid.kruuth wrote:Yep, they're tight. I know I lost some fluid when I changed the pads though.
You don't really have to remove the reservoir cap. It should already have a hole to allow air to go in.OldmanPurdy wrote: You remove the master cylinder cap to allow room for over flow then use channel locks or some other sutibale tool (screw clamp) to compress the piston, it dosen't require much pressure. It helps to have someone watch the master cylinder while you do this to make sure it dosen't overflow, and if it gets close use a suction pump to remover excess fluid.
