cool. hopefully it stays off
just remember that brake fluid does not compress because its basically hydrolic fluid and stays solid
so if your brake fluid is low than it might be your brake pads are getting thinner, when you change your brake pads make sure that the fluid in the res. doesnt overflow when you push the cylinder back into the caliper. keep an eye on the level when you do a brake job and remove some brake fluid if you have to
