sgupta »
https://forums.nicoclub.com/sgupta-u53011.html
Sun Jul 13, 2008 7:23 pm
Hi,
I tried this out today. However, I have got a problem now.
It seems when the car is turned OFF, the brakes are hard and not touching the floor but when the engine is turned ON, the brakes become really mushy and soft and touch the floor resulting in no braking at all.
We have checked all the four brake lines for air in the lines and at the bleeder points, all of them seem to be right with no breaking columns of brake oil coming out from the bleeders when the brake is pressed.
There was a mistake for the first time though when I drained the oil. I ended up emptying the reservoir (or the main brake fluid cylinder) and I guess that has caused some air to enter initially, but after that we did a few more rounds of draining the fluid and bleeding it as mentioned and we haven't found any air trapped bubbles in the lines.
Any suggestions on this!
thanks,subh.
