Maybe i'm highly dyslexic but
I did forget to say s13 if that makes a difference.
Figured out some more things:
Bled the rear calipers correctly the first time, and only took about 3 or 4 pump/bleed cycles. These were new calipers also so they were 100% air.
The fronts however keep kicking out a foamy mix every time I try to bleed them. Gravity bleeding did a good job of getting air bubbles out, however as soon as I push down the pedal i get more bubbles.
My guess... Master cylinder
I only get bubbles out of the front, never the rears. I'm assuming that the master cylinder operates in 2 stages, one for the front then one for the rear. I bet the o-ring for the fronts went bad.
