Perrenial Badass wrote:It's a vacuum issue, the heater is turning on pretty much. Not much of a problem, just replace all the vacuum lines you can when you do your tune up. It will probably need a recharge anyway, but the AC won't work right with a vacuum leak.
Yes I believe you are right. It doesnt just blow uncooled air, it blows air hotter than the air outside. Definitely like the heater. I changed it to full heat setting and it felt exactly the same; there was no difference. I will have all these hoses replaced, but I can't afford a full tune up right now. Its too hot in Texas to run with the heater on.
Are the vacuum lines expensive, and does it take a long time to replace them? I dont have that much money but I have a little bit. I am trying to figure out how much this would cost me, because I need to fix it ASAP.
If I took it to a mechanic, what would I tell him is the problem? Like wouldnt I have to tell him what specifically I need him to do?
Modified by cbruffin at 9:42 PM 8/30/2009
