boost problem
lifelicksballs
its probably cuz im a real noob with turbos but why is my bone stock ca running 15psi when i floor it shouldnt be cut off around 6 or 8psi from thestock wastegate
themadscientist
make sure the actuator is not shimmed up from the compressor housing with washers.make sure the actuator rod is not bent.pop the e-clip off the swingvalve end of the actuator and make sure the door swings freely.make sure the actuator hose is clear of obstructions.
btustison
themadscientist wrote:make sure the actuator is not shimmed up from the compressor housing with washers.make sure the actuator rod is not bent.pop the e-clip off the swingvalve end of the actuator and make sure the door swings freely.make sure the actuator hose is clear of obstructions.
And make sure that there is a vacuum/presure hose attached to the actuator, and that it doesn't leak. I discovered that the stock wastegate blows open at right around 15psi so make sure you have presure on the actuator.
float_6969
I was just going to say that. The stock CA T25 WON'T do any more than about 15psi, so I'll bet the vac line going to the wastegate actuator is unhooked, or has a major hole in it.
rico05
Car: 1992 RMS13 w/ CA18DET
TMS, what is wrong with shimming the wg? I have a couple in there and it seems to be fine so far. But I am only shimming for 2psi more, not 8psi more (and with 1 shim per lb/boost, that would be a lot of shims to get 15psi LOL!)
themadscientist
nothing wrong with it. He doesn't want increased boost so that would make it a problem.
rico05
Oh... hahaha! Freaked me out a little!
themadscientist
you should see me in leather shorts, that would make you gouge your eyes out with a screwdriver!
float_6969
Forget the leather shorts. You should just SEE him. That's enough! JK! You know I got mad tyte luv 4 ya TMS.
I'm so white it's not even funny...
themadscientist
get your hand off my knee float, it was a one-time thing man, let it go.
