PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Wed Apr 15, 2015 4:08 pm
Do you have a link to the product?
Typically, there is an input hose (like from charge pipe, or even manifold pressure), and an output hose (which would go to your wastegate).
Most designs are a ball on seat with a spring type regulator. There is a threaded adjustment that changes the preload on the spring to allow for more or less air pressure going to the wastegate (and there is usually a tiny vent hole). To regulate down, the threaded part should be screwed OUT. If you didn't try first running it with it as loose as possible, do that.
You should also try to test it with compressed air going into the manual boost controller (regulated if possible so you know when it'll come on), and verify it opens the wastegate.
