dangeris »
https://forums.nicoclub.com/dangeris-u76570.html
Fri Feb 08, 2008 5:20 am
Here ya go! Let us know how it works out for you but looking at the instructions, it doesn't seem it supports that function. I now on my crackberry, I can transfer my phonebook thru the car, not thru the phone.
Bluetooth® Setup Guide for:2008 Altima Coupe with Navigation System
Below are step-by-step instructions on how to connect your Bluetooth®-enabled compatible phone to your selected vehicle.STEP #1: PREPARE YOUR PHONE
Turn Bluetooth on: 1. From the home screen, select "Settings" 2. Select "Options" 3. Select "Bluetooth" 4. Press the "Menu" button 5. Select "Enable Bluetooth" Name your phone: 6. From the home screen, select "Settings" 7. Select "Options" 8. Select "Bluetooth" 9. Press the "Menu" button 10. Select "Options" 11. Scroll to "Device Name" 12. Change name as desired 13. Press "Escape" key 14. Select "Save"
STEP #2: PREPARE YOUR VEHICLE
1. Press the "Settings" button 2. Select "Phone" 3. Select "Bluetooth Setup" 4. Select "Pair Phone" 5. Select desired entry (overwrite existing or new)
STEP #3: PAIR YOUR PHONE TO THE VEHICLE
1. From the home screen, select "Settings" 2. Select "Options" 3. Select "Bluetooth" 4. Press the "Menu" button 5. Select "Add Device" 6. Select "[MY-CAR]" 7. Enter Passkey 1234 8. Press in "Trackball" to confirm 9. Select "Yes" when asked, "Accept Connection Request From [MY-CAR]?" 10. Select "[MY-CAR]" 11. Select "Device Properties" 12. Change "Trusted" to "Yes" 13. Press "Escape" key 14. Select "Save"
STEP #4: ADDING YOUR CONTACTS TO THE VEHICLE PHONEBOOKThe phonebook can store up to 70 contacts. This device does not support contact transfers via Bluetooth. Option 1: Adding Contacts Via Touchscreen:
1. Press "Setting" 2. Select "Phone" 3. Select "Phonebook" 4. Select "None (Add New)" 5. Select "Keypad" 6. Enter contact name 7. Enter contact number 8. Select "Yes" to add a voice tag 9. Say the name of the contact
Option 2: Adding Contacts Via Call Logs:
1. Press "Setting" 2. Select "Phone" 3. Select "Phonebook" 4. Select "None (Add New)" 5. Select "Outgoing Calls" or "Incoming Calls" 6. Select contact number 7. Select "Yes" to add a voice tag 8. Say the name of the contact
