hamiltzp »
https://forums.nicoclub.com/hamiltzp-u301043.html
Thu Apr 01, 2021 5:47 pm
Hello,
I have a 2009 Sentra with moon roof. I recently had an issue with the drains from the moon roof leaking and causing the driver's side to flood (several inches of water). This apparently took out the bluetooth module - it would keep the radio display lit and run the battery down. I had the dealer fix the drains, but due to the cost, I had them simply remove the bluetooth module. The service rep was very nice and gave me the old module along with it's bracket so I could see what I was dealing with. The service rep also said it was located under the driver's seat, which is why it got flooded out.
I now have another bluetooth module from a junkyard, which I've placed in the bracket, and I want to install it. However, I looked under the driver's seat and I don't see any wiring harness, nor do I see where the bracket would mount. Was the service rep wrong on the location? Where should I be looking?
Thanks,
Zachary Hamilton
