Armendo89 »
https://forums.nicoclub.com/armendo89-u203181.html
Wed May 23, 2012 8:30 pm
This SR20DET head was disassembled, cleaned, inspected, and reassembled with the following components:
-competition 3 angle valve job with 0.040" valve seats
-Valve job performed on a Serdi machine
-cylinder head ported and flow tested on a SuperFlow 600 flow bench using Audie Technology digital interface
-exhaust valve guides replaced with manganese bronze and honed to spec
-all 16 valves reground using Kwikway valve grinding machine
-cylinder head deck milled to ensure flatness(0.010" deckmill)
-valve shims ground to fit Tomei solid lifters
-fwd sr20de valve cover powder-coated black with breather baffles removed and rear breather tube plugged off
-HKS adjustable camshaft gears
-Greddy rocker arm stoppers
-Tomei solid lifter
-Peak Performance race spec valve springs
-oem valve stem seals
-HKS 272 step 3 intake camshaft(228 degrees at 0.050" lift, 12.6mm lift)
-Nismo 280 exhaust camshaft(224 degrees at 0.050" lift, 12.6mm lift), this is an extremely rare camshaft. it was briefly made and I had to buy it directly from a distributor in Japan.
-FWD Cometic 0.040" MLS head gasket
-Nissan Pulsar GTI-R individual throttle bodies cut and rewelded to be used on a rwd configuration sr20 engine. after welding intake plenum port matched.( This head was initially built for a RWD car but the customer backed out and I bought the head so I made a new custom Intake manifold with the individual throttle bodies)
-Profab insulating intake manifold spacer gasket
-444cc top feed injectors (bluebird Injectors)
Now it's time for Engine management and I want to know what you guys think I should do, I appreciate all of your suggestions.
Thank you, Anthony
