Blinkers wont work on 02 Frontier
mywifemademe
Car: 2002 Frontier
I engage the blinker and it flashes once and stops. Sometimes it will flash and sometimes it wont. Same thing with the hazards. Is this the turn signal/flasher unit thats causing the problem? or the relay? Or are those one and the same?
Q451990
:welcome: to NICO!
Do you have a trailer light connection? That's the usual source of brake/tail/signal problems on trucks. Very possible that something is shorted out... Otherwise, I would look to the flasher module.
Check out the service manual for your truck at http://www.nicoclub.com/FSM/ for more information on the flasher and it's location.
Good luck!
Heath
