Bleeding the Clutch?
Kaos
How do you bleed the clutch line? I guess what I am asking is where is the release valve? Is it done the same way as bleeding the brakes?
Chad
PS I found some stuff but none of them say where the release valve is.
YamaOni
Car: Its ugly and green, Its a cefiro dori machine
the release valve is on the slave cylinder, crack the line coming from the clutch master and push in the clutch hold and tighten that line then go to the slave and bleed like brakes.
Kaos
thanks man.
Chad
