srellim234 »
https://forums.nicoclub.com/srellim234-u70891.html
Mon Feb 25, 2008 7:41 am
There's something else going on here other than financial logic to make the statement that you wish you could afford a Rogue. It's not the mpg or the $$$ that were behind your decision. Would you care to enlighten us?
If you bought the Versa for $16.5k and took a hit of $3k, that means you got $13.5 for it. The lowest base price on a new Prius that I see is $21.1k. Add finance charges/interest to that purchase price. If you take the Versa at 25mpg and the Prius at 47mpg over 100,000 miles, assume gas prices will rise to $4/gallon later this year, you'll save only $7,500 dollars in that 100,000 miles. Financially the move isn't justified.
If you could afford the Rogue, you say you'd drive that. Then mpg or environmental concerns aren't the answer.
I'm not defending the Versa as a great car. I'm not particularly pleased with the performance of mine but I can't financially justify getting out of mine right now.
Is there a comfort/performance/quality factor that led to your decision? Why did you do it?
