Excellent work! Have fun with that idle issue I too just recently completed my 21st CA swap, but my 1st automatic and I had to wire it into the KA24E's auto transmission ecu. Keep up th egood work.NeedCAforS13 wrote:haha, bring the car over here chris and that might happen! gas is too damn expensive to drive my a$s all the way to daytona
and Nghi, you're very welcome. we seemed to do really well I impressed even myself with how smoothly it went. No real hitches, and took us 2 days at a leisurely rate. Now if we could only find out that idle problem we'd be set... Its so odd, it pulls as good if not better vaccum at idle than my car (18-19 inhg) and it idles great sometimes. Then it just drops to like 400rpm, and then back up to 1000, then it dies. Its odd because driving it around it felt allright, didn't feel like it had a boost leak or anything like that. We'll do some troubleshooting later, might be a bad idle air valve or something.
p.s. Wiring is so easy, if you can't get a CA wired up, you really should not be working on cars (j/k, but no its really that easy). I guess this was my third CA swap, but still...
Sean
From my memory, I know we had to extend the MAFS wires and we bought a O2 sensor (Bosche) from a 300ZX and it already had the plug and long wires so we didn't need to extend that. Actually some of the harness was longer then needed but we didn't shorten it because we got lazy. If I come up with anything else I will post.2BN_S13 wrote:Do you guys have some sort of write up on the wiring extensions needed? That would be most helpful...
yesnnkfws333 wrote:
On another note, if we didn't wire up the Knock sensor, could it have caused the car to idle real bad and stall as well as barely run until it hits 3000-4000 rpms? The first few startups it was fine but then the idle got horrible.
Good, so I can count on you coming to atlanta, ga to help me (do all the work )?rico05 wrote:Congrats! Sounds about like my swap went. I need to find some local kid with money to blow....Once you install a motor it becomes a disease....you want to do it all the time. I find myself looking into buying a Honda just so I can do a swap.
man you guys have it lucky in the states. Gas just hit $1.15/litre for regular, $1.25/litre for 91 octane, here in canada, which is like $4.60/gal for regular and $5.00/gal for 91 , so don't complain about your 3.00/gal.NeedCAforS13 wrote:haha, bring the car over here chris and that might happen! gas is too damn expensive to drive my a$s all the way to daytona
