ill4na8na2 wrote:Yeah i get completely what your saying. I wouldnt say its more than i was hinting at doing or wanting to do, i mean i have it tore down to the heads as it is, i just wanted to see if it was worth it or not to go through all that when i bought it not running, i'm just someone who hates to go back and do things over again because thiers something that i missed or goes bad after the fact. No this isnt the first time i've bought a car not running or one thats set for awhile, but it is the first that i bought one where a part of it was open, in my case being the upper plenum & Upper timing covers and everything was off an in a box that you remove to get to that point. Currently i have it tore down to the heads anyways, they just arent removed yet. I wouldnt say it was sloppily cared for as much as it was someone with no auto knowledge at all trying to get thier car to running. But the price, body and interior were right so i was willing to take the risk. I was planning on pulling the motor originally and doing as you suggested, then my buddy who has a 91 na was arguing with me to just see if it runs before i do anything. which is what prompted my question.
Gotcha...well, since things are disassembled to this point I'd definitely do as I said and be thorough with it if you really want the best results, and although understanding your buddies sentiment, I feel that circulating crud and possibly further small parts through the engine will not work out well.
Given the reasonable suggestion by itsa300zx, maybe try to clean out as much of the internals as possible, followed by a flushout of some sort with cheap oil and hand circulation where you'd feel any problems and stop, if that works and things look clean then maybe do compression tests on all cylinders and if good, use ATF for the old 1 minute run after that on power (if it starts) for a final clean and if it makes it through that, maybe you're OK. But I'd still be very worried, and all could be avoided by knowing which means disassembly of the rest of the block...especially since it's on a stand and already open, plus that band you found...
