Beancooker »
https://forums.nicoclub.com/beancooker-u42602.html
Wed Feb 28, 2007 8:15 pm
Dude, your tires are a 35 series, and I have 17's with a 40 series, and came stock with a 40 series. Your tires and wheels are not the same height as stock 17's and tires. The difference would be about 3 inches. If the stock tires are a 40 series, but are 235 wide, and your tires are a 35 series, and 245 wide... Here: the sidewall of a 235/40 is 94mm. the sidewall of a 245/35 is 86mm. that is a difference of 8 mm. that is less than half of an inch in height difference in sidewalls. So you added 3" of rim, and have a sidewall that is half an inch smaller. So you gained 2.5". Divide that by 2 since it is split, and you raised your car 1.25 inches when you put those wheels on.
