Ebbtide »
https://forums.nicoclub.com/ebbtide-u45275.html
Wed Nov 19, 2008 5:36 am
LOL, when these belts slip it is loud as hell!
I think you belts are getting worn. They also have to be super tight. I'd not use wd-40. I would replace them if they are older, or just tighten them some more if you think they have some life.
A couple years ago I chased this belt problem for several months. I replaced the belts, alternator, and idler pulley before I decided to tighten the belts to what I thought was the point of snapping. Since then, no problems at all. If you do a search you will find that the squealing belt problem is kind of common, and the amount of tension defies logic.
Good Luck
