sdtouge »
https://forums.nicoclub.com/sdtouge-u17787.html
Wed Aug 10, 2005 8:09 am
those are fuel lines, the 2 metal ones, the return comes from the fpr.
the 4 vacuum lines under the intake mani, actuually you can leave both side unplugged. if you look under there, it will be only bolted on there, not conected vacuum wise. but if you are leaving chacoal canister and sstuff then you should that that and hook itup properly. check the fsm and the stickeis for more info.
