been at the strip again..
BigTone
Car: guess!!!
was drag racing again this weekend..
first..
we had to rebuild the gearbox on Friday (snapped the main output shaft)refitted the box Saturday morning so we could ran in the afternoon..
first run (warm up run to make sure the gearbox worked)we ran a 11.30 @ 137 mph
my last run (cost me a head gasket)
we managed a 10.85 @ 136 mph
the engine is now stripped ready for the new H/G
bentvalves
Car: 89 Silvia K's
hells yea man, so I take it the power being made was on a stock headgasket?
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
holy crap. thats crazy.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
10.85 is no freaking joke man. You've got one hell of a fast car.
mbmbmb23
What HG you running? ARP head studs?
BigTone
Car: guess!!!
cheers everyone..
it was a metal H/G..
yes we are running ARP head studs..
power is now around 720bhp
Bwana
Car: Denali
Damn! Nicely done!
dj_lennon_franz
Car: 1992 240sx
Great job
What gearbox are you using?
BigTone
Car: guess!!!
dj_lennon_franz wrote:Great job
OS Giken long ratio gearbox,OS Giken Uprated Output Shaft,
heres the slip...
r34 gtr
Hell yeah. 720bhp? I wouldn't know what to do with it.
Ca_Silvia
Dude, what do you have done to your motor? 720bhp on a CA **** ya man!
NUT-CSE
Car: 1988 Nissan Exa
720hp!!!!!!
Would you be so kind as to share your engine specs with us?
BigTone
Car: guess!!!
here you go
Engine..
1809 4-cylinder turbo 16v twin cam, (CA 18 DET)Motec engine management system,New loom,Tomei vernier cam pulleys,Metal head gasket 1.2mm,Trust steel H section con rods,Forged pistons,Garrett GT35R/40 Turbo,ND custom exhaust manifold,External wastegate, Large flow custom plenum,80mm throttle body,Port / gas-flow cylinder head,Match / port inlet & exhaust manifolds, Re-shape / equalise combustion chambers,Re-profile valves,One off steel crankshaft,Tomei / HKS re-profile cams,SARD adjustable fuel pressure regulator kit,Dash 8 Fuel line (delivery),Dash 6 Fuel line (return), SARD 1200cc Injectors,Custom made fuel rail,Custom made fuel tank baffled and foam filled,Gp B external fuel pump,Custom large radiator,Stant high pressure radiator cap, Electric fan,Custom made header tank,Custom made vapour tank,Custom large intercooler kit with 3"pipes,Custom made oil catch tank, Large oil cooler,Oil breather system,Blitz SUS air filter, 5bar map sensor.Rusty old NGK's, Evo 7 coilpacks.Greddy B spec 2 boost controller running 2.5bar,Nismo engine mounts.
Ca_Silvia
Steel crank? Baller!
How did you get the EVO 7 coils to work?
CA18-510
thats one hell of a trap, cant wait to see single digits.
r34 gtr
Your crank is fully counterweighted I presume?
S@nt0s
Car: 99 GS300, 89 Silvia, 99 4runner
What that pass made with your 700+ hp?What's up with the first 1/8 peddling it?Tires?
138 trap is good for mid 9's unless its a fwd.....
