Ace2cool »
https://forums.nicoclub.com/ace2cool-u95120.html
Fri Mar 20, 2015 6:11 pm
If it came without, it's most likely an Auto to 5 speed swap. Mine will be running without one as well. However, you can install one and just use it for the launch control.
The reason you don't want to run it off anything else is because you can hold the throttle to the floor and only rev to the set RPM, then as soon as you release the clutch, you have full throttle range. To do it with the E brake complicates things and adds timing issues. Rev limiters are about simplification of launch, not complication.
