Reverend D wrote:Remove the negative cable from the battery. Set up a test light between the cable and the (-) lug. Make the sure test light is visible from inside the truck. Start pulling fuses one at a time till you get the light to go out. Once the the light goes out you now know what circuit was drawing down the battery. then it's just a matter of checking all the things that run on that particular circuit.
noface wrote:yes, and yes or you can use a multimeter set on amps to do the same thing. Set up the leads on mm to read amps (10a setting usually). Neg lead to chassis, and red lead to battery post. If you have a reading... it's flowing current. Then do as said above.
Epic advice guys! I hate anything to do with electrical systems, and I have a short somewhere in another truck of mine and have just installed a battery disconnect at the battery. It's just a ranch truck so it's not too much of a hassle on the days I actually use it. But the fact is I've been lazy, and honestly didn't think it would be as easy as stated above to chase down a wiring issue (and isn't at all on the newer cars, locating which fuse only digs you further into a nightmare in those)
I'm loving the info, some of the KA buildups has me planning for when my newly aquired motor goes south with the first one. Thanks!
