Battery relocation to truck bed
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
hawaii_620
Car: 75 Datsun 620
I'm doing a battery relocation to the bed of my 620 and just wanted to get some feedback. Attached is the wire diagram that I came up with to do this job. Please, if anyone out there sees any flaws of points of concern with this plan please tell me as I wish not to have my truck burn to the ground.
Wire I'm using is 4 gage.
Why am I doing this? Because my original battery try was rusted to pieces and I'm doing this so I can drive my truck while I work on repairing that area of the engine bay. Also if I ever do a KA or SR20 swap, and also because it looks a lot cleaner on the inside of the engine bay too!
Thanks,
Kyle
PEZi
I'm slightly confused by the fuses... other than that.. solid
this is my setup... except yours doesn't have/need the master disconnect
hawaii_620
Car: 75 Datsun 620
Yeah, those were the fuses I had on hand. But I'm not to sure what fuses to run with though.
PEZi
take a look at a wiring diagram if you can, either from a chiltons/haynes/FSM
it'll tell you if and what type of fuses to use
hawaii_620
Car: 75 Datsun 620
I have a Haynes manual so I'll take a look. So you aren't running any fuses inline with that setup? I've been looking up information on forums about other battery relocation setups (domestics/imports) and they usually mention running a fuse close to the battery. I guess in case of a accidental ground of the positive cable it will bust and help prevent a fire. But I'm not sure, because I also have come across just as much information about NOT running a fuse, hence my inquiry on this Nissan forum. What type of disconnect switch are you using?
PEZi
yeah.. there just really shouldn't be a need for running fuses like that
that's kinda what those stupid fusible links were made for
this on the other hand is the switch here
Return to “Datsun 620”
