SilverTwin(OH) »
https://forums.nicoclub.com/silvertwin-oh-u29397.html
Fri Feb 19, 2010 5:53 pm
Black with yellow stripe is the negative (ground), it should be bolted to the firewall directly behind the battery. Verify it to confirm proper orientation.
White wire is the positive lead to the starter.Red wire is likely the positive (power source) for an amplifier or other aftermarket accessory.Large wire in loom is positive batter cable.
The battery is in backwards.
As robomatic12 stated, if you hooked them up in backwards, you likely blew the main fuse at minimum. Check the fuses in the small box directly in front of the battery.
