Basic little mods...
Cory_Marshall
Car: 1992 Nissan 240SX Fastback, Champagne, 5 Spd., Tan interior, SUPER HICAS
If you put Headers, Injectors,Performance Exhaust System front to back and a cold air intake are you going to get even a worth while increase in power..
I figured if you get even 15-20HP out of that it isn't too bad? Is that about what you would get?
danielsan
Car: 1991 240sx coupe SE
why do people think bigger injectors will get them more power?? has your car ever ran rich?? it wastes gas, power, and fouls out your plugs, could mess up the o2 sensor, thats what bigger injectors will do if your not running boost.
you will get around maybe 10hp if your lucky.
Cory_Marshall
I dont have Bigger injectors in my car..
The only thing out of this I have is an exhaust system and I got one because the car needed a new one...
ALOT of people do these mods so I figued I would ask
danielsan
i thought your planning on running bigger injectors since you listed "injectors" in your mod list.
my bad.
those mods should increase the throttle response and top end.
apollas
Car: rb20 type-m
the i/h/e combo will do very minimum. reason why they are so common is because they are like the easiest mods to put on a car. also, people like the sound of the CAI and exhaust. youll get like 2-3hp, maybe.
direktdrive
Car: Nissan S14 - Zenki
apollas wrote:the i/h/e combo will do very minimum. reason why they are so common is because they are like the easiest mods to put on a car. also, people like the sound of the CAI and exhaust. youll get like 2-3hp, maybe.
2-3 hp maybe? I beg to differ. I've seen i/h/e combo dynos and they aren't just 2-3 hp gains. Around 15 hp sounds more reasonable.
Regardless though, I agree that i/h/e combo will do minimum. Nevertheless, if your exhaust is rusted, it doesn't hurt to take the extra mile to run a performance exhaust system.
