S14Jer »
https://forums.nicoclub.com/s14jer-u105909.html
Sun Sep 28, 2008 3:43 pm
I am having all kinds of trouble lately... Been searching for 2 days to try to find a problem similar to mine but no luck.
I bought a 95 240 from a guy and i put a boost gauge on it and it is running at least 15 PSI on stock injectors. It has a walbro 255 fuel pump but no boost gauge. How could it be running higher than stock boost? I thought the stock waste gate cuts it off at like 7-10?
Also its running like it has a boost leak now, gets pretty shaky when i start to build boost and just doesnt feel like it has the same power. Under no boost engine runs fine. Also in 5th gear it seems to be able to boost just fine... I am so lost can anyone give me any insight? Im going to boost leak test it when I get some time.
When the turbo is spooling up, it kind of sounds like an exhaust leak or something, bsically some kind of noise coming from the turbo that i cant figure out.
Edit: I have a blacktop sr20det stock turbo and wastegate, Greddy type R BOV
Modified by S14Jer at 8:27 PM 9/28/2008
