Z32man wrote:Okay well I have taken all of the timing belt covers off. The timing belt isn't covered in oil. Does that mean it has to be the oil pump seal/gasket? Would that cause oil to be on the alternator as well?
When you mention the alternator having oil on it, are you SURE it's engine oil and not ps fluid (trans fluid)? When the PS reservoir leaks it will usually dump on the alternator as the lines and connections encourage this.
I agree about the front seal should not have caused a massive oil pressure loss or dump, I'd be sure to check the oil lines to the front cooler as mentioned and even oil feeds to the turbos.
Also, be sure that you actually ARE losing oil as the OEM oil pressure sender is notorious for "0" readings, especially when old and especially out of the blue or intermittently in my experience with both NA and TT.
Hope this helps!
