Ok so I'm new to this club/site. I really need help and I hate myself for admitting it, but its the truth. My '82 Datsun 720 4x4, failed smog (I live in California), So I rebuilt the carb ,replaced the plugs, wires, cap, rotor, air filter, fuel cap and vacume lines. I took it back to the smog shop and as soon as they put it in the bay it started miss firing and the idle went from 900 rpm to 1600 rpm and stayed there. Ive checked the spark on all cylinders its good, then I checked the distributor at tdc its good, checked valve timing its good. Checked plug gaps their good, checked timing with two different lights its good, still has a damn miss
. Now for the idle, I adjusted the idle screw, then when that didn't work, I adjusted the accelerator pump spring screw and it did a little after two turns, but then nothing after those two turns. I want to adjust the air fuel mix screws but I hate the idea of having to take the back half of the carb apart, because the screws are blocked by a bunch of emission garbage! I only have a week left to resmog it, so any help would be awesome. Sorry for rambling, I just need it to pass smog!
